Displays egress traffic counts or ingress traffic counts for each QoS profile on the specified ports.
| port_list | Specifies one or more slots and ports. |
| egress | Specifies the display of egress traffic counts. Default. |
| bytes | Specifies to display ingress or egress traffic counts in bytes. |
| packets | Specifies to display ingress or egress traffic counts in packets. |
| no-refresh | Specifies a static snapshot of data instead of the default dynamic display. |
| refresh | Specifies a continuous refresh of output. |
| port-number | Displays port number instead of display string. |
Displays egress packet counts in real-time.
The bottom line in the real-time display shows keys that you can press to change the display. For example, the spacebar toggles the display between QoS traffic counts in either packets or bytes.
If you specify the no-refresh parameter, the system displays a snapshot of the data at the time you issue the command.
If you do not specify a port number or range of ports when displaying ingress or egress traffic counts, traffic counts are displayed for all ports.
# show ports 1:1-1:2 qosmonitor Qos Monitor Req Summary Thu Mar 2 10:58:23 2006 Port QP1 QP2 QP3 QP4 QP5 QP6 QP7 QP8 Pkt Pkt Pkt Pkt Pkt Pkt Pkt Pkt Xmts Xmts Xmts Xmts Xmts Xmts Xmts Xmts ================================================================================ 1:1 0 0 0 0 0 0 0 0 1:2 0 0 0 0 0 0 0 0 ================================================================================ > indicates Port Display Name truncated past 8 characters Spacebar->Toggle screen 0->Clear counters U->Page up D->Page down ESC->exit
# show ports 1:1-1:2 qosmonitor ingress Qos Monitor Req Summary Thu Mar 2 10:59:28 2006 Port IQP1 IQP2 IQP3 IQP4 IQP5 IQP6 IQP7 IQP8 Pkt Pkt Pkt Pkt Pkt Pkt Pkt Pkt Xmts Xmts Xmts Xmts Xmts Xmts Xmts Xmts ================================================================================ 1:1 0 0 0 0 0 0 0 0 1:2 0 0 0 0 0 0 0 0 ================================================================================ > indicates Port Display Name truncated past 8 characters Spacebar->Toggle screen 0->Clear counters U->Page up D->Page down ESC->exit
The ingress information was added in ExtremeXOS 11.0.
Also, you must specify the ports in ExtremeXOS 11.0.
The egress and no-refresh keywords were added in ExtremeXOS 11.3.
The bytes and packets keywords, as well as the toggling functionality, were added in ExtremeXOS 11.4.
The refresh keyword was added in ExtremeXOS 16.1.
